Nikon Coolpix L18 LCD Screen Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix L18 LCD Screen Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 LCD Screen Replacement: шаг 2, изображение 1 из 2 Nikon Coolpix L18 LCD Screen Replacement: шаг 2, изображение 2 из 2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 LCD Screen Replacement: шаг 3, изображение 1 из 1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 LCD Screen Replacement, LCD Screen: шаг 4, изображение 1 из 1
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 LCD Screen Replacement: шаг 5, изображение 1 из 1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  6. Nikon Coolpix L18 LCD Screen Replacement: шаг 6, изображение 1 из 1
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
Заключение
8 участников успешно повторили данное руководство.
Nonny
Участник с: 10/11/10
219 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 9-23, Regan Fall 2010 Участник Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 членов
Автор 10 руководств
4 Комментариев
Good work! Appreciate it.
Oasis World - Ответить
I need a new LCD screen replacement. A link to buy a new one?
William Pullman - Ответить
Where can I get a replacement LCD screen for a Nikon L18 camera?
I found one for my Nikon Coolpix L18 on eBay.
Mark Fraylick -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 7,053
