Nikon Coolpix L18 Logic Board Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix L18 Logic Board Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 Logic Board Replacement: шаг 2, изображение 1 из 2 Nikon Coolpix L18 Logic Board Replacement: шаг 2, изображение 2 из 2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 Logic Board Replacement: шаг 3, изображение 1 из 1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 Logic Board Replacement, Front Cover: шаг 4, изображение 1 из 1
    • Pry back the front cover of the camera starting from the right side.
  5. Nikon Coolpix L18 Logic Board Replacement, LCD Screen: шаг 5, изображение 1 из 1
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  6. Nikon Coolpix L18 Logic Board Replacement: шаг 6, изображение 1 из 1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  7. Nikon Coolpix L18 Logic Board Replacement: шаг 7, изображение 1 из 1
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
  8. Nikon Coolpix L18 Logic Board Replacement, Lens: шаг 8, изображение 1 из 2 Nikon Coolpix L18 Logic Board Replacement, Lens: шаг 8, изображение 2 из 2
    • Remove the 6 Phillips #00 screws anchoring the LCD base to the motherboard.
    • Remove the LCD base plate.
  9. Nikon Coolpix L18 Logic Board Replacement: шаг 9, изображение 1 из 1
    • Gently pull the lens ribbon out.
  10. Nikon Coolpix L18 Logic Board Replacement: шаг 10, изображение 1 из 1
    • Desolder the connection of the motherboard to the lens ribbon using a soldering iron and desoldering wick.
  11. Nikon Coolpix L18 Logic Board Replacement: шаг 11, изображение 1 из 1
    • Lift up the black and copper covering on the left side of the camera.
  12. Nikon Coolpix L18 Logic Board Replacement: шаг 12, изображение 1 из 1
    • Pull the wiring at the top right of the camera away from the lens with tweezers.
  13. Nikon Coolpix L18 Logic Board Replacement: шаг 13, изображение 1 из 1
    • Remove the cross-hair shaped wire cap to the left of the lens.
  14. Nikon Coolpix L18 Logic Board Replacement: шаг 14, изображение 1 из 2 Nikon Coolpix L18 Logic Board Replacement: шаг 14, изображение 2 из 2
    • Remove the 3 screws holding the lens to the camera frame.
    • Two 3.8mm black Phillips #00 screws on the sides of the lens.
    • One 4.6mm silver Phillips #00 screw on the bottom of the lens.
  15. Nikon Coolpix L18 Logic Board Replacement: шаг 15, изображение 1 из 1
    • There is a screw behind flash tube holding lens. Remove it, then gently pull the lens out. Be sure that the lens's ribbon clears the motherboard.
  16. Nikon Coolpix L18 Logic Board Replacement, Logic Board: шаг 16, изображение 1 из 2 Nikon Coolpix L18 Logic Board Replacement, Logic Board: шаг 16, изображение 2 из 2
    • Remove the tape on the top of the logic board.
  17. Nikon Coolpix L18 Logic Board Replacement: шаг 17, изображение 1 из 1
    • Remove the 4 Phillips #00 screws holding the top of the logic board onto the camera frame.
  18. Nikon Coolpix L18 Logic Board Replacement: шаг 18, изображение 1 из 1
    • Desolder the joint of the top and back of the logic board using a soldering iron and desoldering wick.
    • You will need to have soldering equipment to complete this step.
  19. Nikon Coolpix L18 Logic Board Replacement: шаг 19, изображение 1 из 1
    • Move the top of the logic board to the side, exposing the top of the frame.
    • Desolder the two connections on the top right of the logic board using a soldering iron and desolering wick.
Заключение
3 участников успешно повторили данное руководство.
Aaron
Участник с: 10/06/10
278 Репутация
1 руководство автора
Команда
Cal Poly, Team 9-23, Regan Fall 2010 Участник Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 3,547
