Введение
If your camera does not power on, then most likely you would have to replace your batteries. Follow instruction on this guide to remove your old batteries and replace them.
Make sure to turn off your camera before replacing the batteries.
Turn the camera upside down so you can see the battery chamber.
Push the battery chamber lock to the right to open it.
Slide the cover down to unhook the battery door.
Remove the old batteries from the battery chamber.
Replace the batteries with new ones.
Еще один человек закончил это руководство.
