Nikon Coolpix L330 Front Housing Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix L330 Front Housing Replacement, Back Housing: шаг 1, изображение 1 из 3 Nikon Coolpix L330 Front Housing Replacement, Back Housing: шаг 1, изображение 2 из 3 Nikon Coolpix L330 Front Housing Replacement, Back Housing: шаг 1, изображение 3 из 3
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
  2. Nikon Coolpix L330 Front Housing Replacement: шаг 2, изображение 1 из 2 Nikon Coolpix L330 Front Housing Replacement: шаг 2, изображение 2 из 2
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
  3. Nikon Coolpix L330 Front Housing Replacement, Front Housing: шаг 3, изображение 1 из 1
    • Remove the four 1.5x2.5mm screws in the battery housing using a PH000 screw head.
  4. Nikon Coolpix L330 Front Housing Replacement: шаг 4, изображение 1 из 1
    • Remove the two 1.5x2.5mm screws below the flash unit using a PH000 screw head.
  5. Nikon Coolpix L330 Front Housing Replacement: шаг 5, изображение 1 из 3 Nikon Coolpix L330 Front Housing Replacement: шаг 5, изображение 2 из 3 Nikon Coolpix L330 Front Housing Replacement: шаг 5, изображение 3 из 3
    • Remove the black tape covering the electrical connections.
    • Remove the 1.5x2.5mm screw using a PH000 screw head.
    • Desolder the six marked wires.
    • The screen has been removed as well as the back-plate in this step, however they need not be removed to replace the front housing.
  6. Nikon Coolpix L330 Front Housing Replacement: шаг 6, изображение 1 из 2 Nikon Coolpix L330 Front Housing Replacement: шаг 6, изображение 2 из 2
    • Insert a plastic opening tool between the front housing and inner frame.
    • Lever the tool to slide the front housing forward.
  7. Nikon Coolpix L330 Front Housing Replacement: шаг 7, изображение 1 из 3 Nikon Coolpix L330 Front Housing Replacement: шаг 7, изображение 2 из 3 Nikon Coolpix L330 Front Housing Replacement: шаг 7, изображение 3 из 3
    • Position the fingers of one hand on the inner frame and the other hand around the lens barrel.
    • Pull the front housing away from the inner frame.
Заключение
Rajeev
Участник с: 02/09/16
596 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 2-10, Cagle Spring 2016 Участник USF Tampa, Team 2-10, Cagle Spring 2016
USFT-CAGLE-S16S2G10
4 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 909
