Введение
This guide gives a step by step procedure to remove the front housing for internal repairs.
Выберете то, что вам нужно
There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
Two 1.5x2.5mm screws on the right side.
Two 1.5x2.5mm screws on the underside.
Two 1.5x2.5mm screw on the left side.
After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
Remove the back housing of the camera by lifting it directly up.
Remove the four 1.5x2.5mm screws in the battery housing using a PH000 screw head.
Remove the black tape covering the electrical connections.
Remove the 1.5x2.5mm screw using a PH000 screw head.
Desolder the six marked wires.
Insert a plastic opening tool between the front housing and inner frame.
Lever the tool to slide the front housing forward.
Position the fingers of one hand on the inner frame and the other hand around the lens barrel.
Pull the front housing away from the inner frame.
