Nikon Coolpix L340 Battery Replacement
  1. Nikon Coolpix L340 Battery Replacement, Battery: шаг 1, изображение 1 из 2 Nikon Coolpix L340 Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera
    • If the camera lens its pointing towards you, there should be a small lever on the right hand side
    • Take this lever and push it away from your body, while simultaneously pulling upwards
  2. Nikon Coolpix L340 Battery Replacement: шаг 2, изображение 1 из 2 Nikon Coolpix L340 Battery Replacement: шаг 2, изображение 2 из 2
    • Once you have pulled up, four batteries will appear underneith
    • Note how there are two batteries facing upwards (circled in red)
    • and two batteries facing downwards (circled in orange)
    • When the new batteries are placed back in the camera, they should be put back in this same orientation
  3. Nikon Coolpix L340 Battery Replacement: шаг 3, изображение 1 из 1
    • Take out each of the batteries
  4. Nikon Coolpix L340 Battery Replacement: шаг 4, изображение 1 из 1
    • When all of the batteries have been removed you should see four places for four new batteries to be inserted
Заключение
2 участников успешно повторили данное руководство.
Nikki Butts
Участник с: 03/04/16
179 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 Участник UMass Dartmouth, Team 3-3, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G3
4 членов
Автор 8 руководств
4 Комментариев
Hi, I just replaced my Nikon Coolpix L340's batteries with new AAs and have followed all steps correctly but my camera is still saying 'battery exhausted' when I try turning it back on. Any ideas why it's not working?
Thank you!
Mia - Ответить
The negative terminal must be raised like the Duracell Ultra. The Energizer MAX and other AAs have a FLAT negative terminal. The manual warns against them.
thestevelink -
No lever, only recessed button
ccpotts47 - Ответить
thestevelink - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 22
За последние 30 дней: 125
За всё время: 9,522
