Nikon Coolpix L830 Shutter Button Replacement
Выберете то, что вам нужно
    1. Nikon Coolpix L830 Shutter Button Replacement, Back Casing: шаг 1, изображение 1 из 1
      • Use a Phillips #000 screwdriver to unscrew the two 3.0mm Phillips screws located on the side of the camera with the HDMI port.
      • The HDMI port side will be on the left if you are looking at the back of the camera with the LCD monitor.
      • One screw is located under the gray flap.
      Спросите у FixBot
      Добавить комментарий
    2. Nikon Coolpix L830 Shutter Button Replacement: шаг 2, изображение 1 из 1
      • Unscrew the five 3.0mm Phillips #000 screws that are located on the bottom side of the camera.
      Спросите у FixBot
    3. Nikon Coolpix L830 Shutter Button Replacement: шаг 3, изображение 1 из 1
      • Unscrew the 4.0mm Phillips #000 screw located underneath the grey flap on the side of the camera with the "DC IN 5.0 V" marker.
      • This will be on the right if you are looking at the back LCD monitor side.
      • Unscrew the exposed 3.0mm Phillips #000 screw on the same side.
      Спросите у FixBot
    4. Nikon Coolpix L830 Shutter Button Replacement: шаг 4, изображение 1 из 1
      • Press the flash button to open the flash component.
      • Remove the 3.0mm Phillips #000 screw located directly in-between the two arms.
      Спросите у FixBot
    5. Nikon Coolpix L830 Shutter Button Replacement: шаг 5, изображение 1 из 1
      • Open the LCD monitor to reveal two 2.0mm Phillips screws.
      • Remove the 2.0mm Phillips #000 screws.
      Спросите у FixBot
    6. Nikon Coolpix L830 Shutter Button Replacement: шаг 6, изображение 1 из 2 Nikon Coolpix L830 Shutter Button Replacement: шаг 6, изображение 2 из 2
      • Make sure to open the plastic grey flaps on either side of the camera before proceeding with this step.
      • Insert a plastic opening tool between the back and front surface components of the camera.
      • Wiggle the plastic opening tool backwards and forwards along the top edge until the back surface comes off.
      • Remove the back casing gently to not damage the LCD ribbon connector or inner camera components.
      Спросите у FixBot
    7. Nikon Coolpix L830 Shutter Button Replacement: шаг 7, изображение 1 из 2 Nikon Coolpix L830 Shutter Button Replacement: шаг 7, изображение 2 из 2
      • Gently pull the LCD ribbon connector up to allow the back casing to be completely removed.
      Спросите у FixBot
    1. Nikon Coolpix L830 Shutter Button Replacement, Shutter Button: шаг 8, изображение 1 из 1
      • Open the battery panel on the bottom of the camera by pushing the slider up and tugging the battery panel to the right.
      • Remove the 3.0mm Phillips screw in the top battery panel.
      • The screw is located in the dark recesses at the end of the battery chamber, which will make screw removal difficult. Be gentle to avoid stripping screw.
      Спросите у FixBot
    2. Nikon Coolpix L830 Shutter Button Replacement: шаг 9, изображение 1 из 1
      • Remove the 3.0mm Phillips #000 screw located above the grey power flap on the side of the camera.
      Спросите у FixBot
    3. Nikon Coolpix L830 Shutter Button Replacement: шаг 10, изображение 1 из 2 Nikon Coolpix L830 Shutter Button Replacement: шаг 10, изображение 2 из 2
      • Use your finger to gently pull up the wire ribbon which connects the shutter button to the motherboard.
      • The wire ribbon is located at the top right corner of the motherboard.
      Спросите у FixBot
    4. Nikon Coolpix L830 Shutter Button Replacement: шаг 11, изображение 1 из 2 Nikon Coolpix L830 Shutter Button Replacement: шаг 11, изображение 2 из 2
      • Insert the blue plastic opening tool between the main casing and the shutter component.
      • Wiggle the plastic opening tool up and down to pry off the shutter component.
      Спросите у FixBot
    5. Nikon Coolpix L830 Shutter Button Replacement: шаг 12, изображение 1 из 2 Nikon Coolpix L830 Shutter Button Replacement: шаг 12, изображение 2 из 2
      • Unscrew the single 2.0mm Phillips #000 screw located on the dark brown strip on the back of the shutter button panel.
      • Once the Phillips screw is removed, gently take off the metal component with your hand or a wedge tool.
      • The on/off switch is not connected to the metal component, so be sure to keep track of it when removing.
      • Once the metal component is removed, the shutter button should be the only remaining part connected to the black shutter casing.
      Спросите у FixBot
    6. Nikon Coolpix L830 Shutter Button Replacement: шаг 13, изображение 1 из 2 Nikon Coolpix L830 Shutter Button Replacement: шаг 13, изображение 2 из 2
      • Remove the final two 2.0mm Phillips #000 screws, releasing the shutter button.
      • The shutter component has a spring attached. Be sure to carefully remove the shutter button and keep track of the small spring.
      Спросите у FixBot
Заключение
Taylor Hetrick
Участник с: 10/30/16
327 Репутация
Автор 2 руководств
Команда
Baylor, Team 4-4, Williams Fall 2016 Участник Baylor, Team 4-4, Williams Fall 2016
BU-WILLIAMS-F16S4G4
3 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 41
За всё время: 2,820
