Nikon Coolpix L840 Motherboard Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix L840 Motherboard Replacement, Motherboard: шаг 1, изображение 1 из 3 Nikon Coolpix L840 Motherboard Replacement, Motherboard: шаг 1, изображение 2 из 3 Nikon Coolpix L840 Motherboard Replacement, Motherboard: шаг 1, изображение 3 из 3
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Motherboard Replacement: шаг 3, изображение 1 из 2 Nikon Coolpix L840 Motherboard Replacement: шаг 3, изображение 2 из 2
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
Заключение
3 участников успешно повторили данное руководство.
Abraham Lozano
Участник с: 04/11/16
595 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 1-11, Maness Spring 2016 Участник Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 членов
Автор 10 руководств
2 Комментариев
I was trying to find how to replace the CCD lens sensor on the Nikon Coolpix L840
waynelguyton - Ответить
My camera display will work for a bit, but then goes off. Subsequent efforts to start it yield poor results. If I pick it up and try again in a few hours, I may have a short time to work before the screen goes dark. The batteries are new. I think this might be a case of blown capacitors on board, but I could use insight. The motherboard costs more than the camera now.
Stephen Scanlan - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 16
За всё время: 1,964
