Введение
If you have a jammed button or if you simply want to replace a part on your Nikon Coolpix P100 camera, then this guide is perfect for you! This guide will help users easily replace a broken back button on your Nikon Coolpix P100 camera.The only required tools you need are a Phillips #00 Screwdriver and a iFixit Opening Tool.
Before using this guide make sure that the camera is powered off!
Выберете то, что вам нужно
On the left side of the camera, remove two screws using a Phillips #00 screwdriver.
