Введение
This will show you how to open up the camera and replace the camera flash.
Выберете то, что вам нужно
On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two marked screws.
On the right side of the camera, remove the first visible screw above the HDMI and A/V OUT cover.
Lift the HDMI and A/V OUT cover to access the hidden screw between the two ports.
Remove the screw
Turn the back of the camera toward you.
Lift the display panel and remove the two marked screws
Use a plastic iFixit opening tool to gently loosen the top and sides of the camera.
Before fully opening the camera, identify the two marked ribbon cables
Properly detach the ribbons before proceeding
Use a plastic iFixit opening tool to carefully loosen the metal plate.
Remove the metal plate to access the camera's motherboard.
2 участников успешно повторили данное руководство.
