Nikon Coolpix P510 Battery Removal Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix P510 Battery Removal Replacement, Battery Removal: шаг 1, изображение 1 из 1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 Battery Removal Replacement: шаг 2, изображение 1 из 2 Nikon Coolpix P510 Battery Removal Replacement: шаг 2, изображение 2 из 2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
Заключение
Brian Hulsey
Участник с: 03/31/15
1 461 Репутация
Автор 6 руководств
Команда
Colorado Springs, Team 2-2, Panko Spring 2015 Участник Colorado Springs, Team 2-2, Panko Spring 2015
UCCS-PANKO-S15S2G2
3 членов
Автор 12 руководств
3 Комментариев
Even a 3 grader can figure this out. My problem is that I do this and the battery doesn't come up. It's stuck. What should I do???
victoria - Ответить
Victoria, has had that problem too. In my case the battery was bloated. I had to wiggle it out with a butter knife until I could get a grip on it. I had to replace the battery.
david murray - Ответить
Thank you so much for this information. I used a metal nail file and small pliers. It worked and the battery was swollen
klrider1961 -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 32
За всё время: 4,126
