Введение
If you are having issues with your LCD, this guide will help you replace it with a minimal effort. This part is easy to get to, and easy to replace. Other than a screwdriver and a plastic opening tool, nothing else is needed to accomplish this.
Выберете то, что вам нужно
Flip the camera over and push the tab on the battery cover to open the battery compartment.
Push the little yellow tab to allow the battery to slide out.
With the tab pushed out, pull the battery out.
Extend the LCD screen out and turn the camera upside down to get access to the screws on the bottom.
Use a plastic opening tool to trace around the screen to pop the front and back section apart.
Unplug the ribbon cables on the side of the chip under the LCD by simple pulling lightly on them.
The chip has an adhesive on it to keep it attached to the LCD, and you will need to use a plastic opening tool to get it off.
5 участников успешно повторили данное руководство.
