Введение
Replace the eyepiece (plastic rectangular piece around the viewfinder) if it is loose, broken, or lost.
Запчасти
Никакие детали не требуются.
  1. Use your finger to push the notch of the compartment door to the center of the camera body. Release the compartment door, and it will swing open. Remove the existing battery with your fingers.
    • Use your finger to push the notch of the compartment door to the center of the camera body.
    • Release the compartment door, and it will swing open.
    • Remove the existing battery with your fingers.
  2. Use a Phillips #000 Precision Screwdriver for all of the following steps. Remove both 4.5 mm screws holding the bottom into place. Remove both 4.5 mm screws holding the side into place.
    • Use a Phillips #000 Precision Screwdriver for all of the following steps.
    • Remove both 4.5 mm screws holding the bottom into place.
    • Remove both 4.5 mm screws holding the side into place.
    • Remove the 4.5 mm screw underneath the A/V flap.
    • Remove the 4.0 mm screw on the left-side wrist strap loop.
  3. Lift up the LCD screen to reveal the two screws. Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws that hold the arm in place.
    • Lift up the LCD screen to reveal the two screws.
    • Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws that hold the arm in place.
  4. Carefully lift the back cover from the camera.
    • Carefully lift the back cover from the camera.
    • Do NOT completely remove the back cover from the camera yet. There is a data transfer ribbon connecting the LCD screen to the motherboard.
  5. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Press your finger on the top of the latch and pull it down and toward you to open the safety latch and free the ribbon. Be careful when releasing the safety latch because it is fragile and may break easily.
    • Press your finger on the top of the latch and pull it down and toward you to open the safety latch and free the ribbon.
    • Be careful when releasing the safety latch because it is fragile and may break easily.
    • Slide the ribbon out from its socket.
    • It is now safe to completely remove the back cover from the camera.
  7. Use a Phillips #000 Precision Screwdriver for all of the following steps. Remove the seven 4.0 mm screws that connect the metal plate to the motherboard
    • Remove the seven 4.0 mm screws that connect the metal plate to the motherboard
    • Remove the three 4.0 mm screws that connect the metal hinges to the camera body.
  8. Carefully lift the metal backing from the motherboard.
    • Carefully lift the metal backing from the motherboard.
    • Do NOT completely remove the metal backing yet. There is a data transfer ribbon connecting the metal backing to the motherboard.
  9. Press your finger on the top of the latch and pull it down and towards you to open the safety latch and free the ribbon. Be careful when releasing the safety latch because it is fragile and may break easily.
    • Press your finger on the top of the latch and pull it down and towards you to open the safety latch and free the ribbon.
    • It is now safe to completely remove the metal backing from the camera.
  10. Using a Phillips #000 Precision Screwdriver, remove the 3.0 mm screw that holds the eyepiece in place.
    • Using a Phillips #000 Precision Screwdriver, remove the 3.0 mm screw that holds the eyepiece in place.
  11. Using a plastic opening tool, carefully unlatch the safety latch that holds the eyepiece data transfer ribbon in place.
    • Using a plastic opening tool, carefully unlatch the safety latch that holds the eyepiece data transfer ribbon in place.
  12. Remove the eyepiece from the camera.
    • Remove the eyepiece from the camera.
Заключение
Elizabeth Kamine
Участник с: 22.01.2015
655 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 20-14, Maness Winter 2015 Member of Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 членов
Автор 6 руководств
Один комментарий
Excellent Illustrative photographs and instructions
Charles Ikerman - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 6
За всё время: 440
