Введение
Note that the LCD screen display and the glass screen are separate parts.
Выберете то, что вам нужно
Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
Push the door open, and remove the existing battery with your fingers, per images 2-3.
Remove both 4.5 mm screws holding the bottom into place.
Remove both 4.5 mm screws holding the side into place.
Remove the 4.5 mm screw underneath the A/V flap.
Remove the 4.0 mm screw on the left-side wrist strap loop.
Lift up the LCD screen to reveal the two screws.
Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws that hold the arm in place.
Press your finger on the top of the latch and pull it down and towards you to open the safety latch and free the ribbon.
Slide the ribbon out from its socket.
Using a Phillips #000 Precision Screwdriver, remove the two 6.0 mm screws from the inner back panel that hold the LCD screen arm in place.
Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws.
Remove the plastic cover from the LCD screen arm.
Lift and rotate the plastic connector counter-clockwise, clockwise, then counter-clockwise again.
Remove the plastic connector from the LCD screen arm.
Using a Phillips #000 Precision Screwdriver, remove the two 4.0 mm screws.
Take off the plastic covering to reveal the inner components of the LCD screen.
Using a Phillips #000 Precision Screwdriver, remove the four 3.0 mm screws.
Using your fingers, remove the two plastic borders that case the LCD screen.
Using a Phillips #000 Precision Screwdriver, remove both 3.5 mm screws from either side of the LCD screen.
Remove the LCD screen from the screen cover.
2 участников успешно повторили данное руководство.
4 Комментариев
Hello Elizabeth,
I have just followed the video’s for replacing a screen on my Coolpix P90.
The procedure was excellent and for an old Australian (born 1931) I never had a problem.
Just one question, is there a special way for reconnecting the data transfer ribbon.
Just cannot reconnect.
Thank you.
Regards, Noman
QLD Australia.
Help! I must be missing something. I only need to replace the screen and I can’t get the angled screen to lay flat. Because of this I cant access the two screws on the back “extension” piece allowing me to remove the plastic cover on the back of the screen. The camera is a coolpix P90. Any advice?
I also need to know where to buy a new screen.
Everywhere I look on line there are only parts listed for newer models.
Thanks, Allen
