Введение
This is the first part to taking apart your Nikon Coolpix S210.
Выберете то, что вам нужно
Place thumb on the battery cover panel on the bottom of the device.
Slide the panel to the right away from the camera.
Slide the orange latch outward towards the corner of the camera.
The battery should pop out.
Remove the battery and reattach the cover.
Thank You!!! Amazing how easily I can complicate anything!! You are my hero. Retro picture taking ~ here I come!!
After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
Carefully pry the back case away from the camera and then gently lift it off.
To reassemble your device, follow these instructions in reverse order, paying careful attention to the locations of the different sizes of screws.
Еще один человек закончил это руководство.
Один комментарий
What about the front case so I can replace the flash board on top?
