Введение
Remove the circuit board cover so they can proceed to remove the circuit board or fix the lens.
Выберете то, что вам нужно
Place thumb on the battery cover panel on the bottom of the device.
Slide the panel to the right away from the camera.
Slide the orange latch outward towards the corner of the camera.
The battery should pop out.
Remove the battery and reattach the cover.
After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
Carefully pry the back case away from the camera and then gently lift it off.
To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
After removing the LCD screen, unscrew the four 3.8mm screws that hold down the metal plate
Unscrew the 2.5mm screw next to the wrist-strap mount.
Position the camera with the lens facing down and the shutter button facing you.
Lift the metal plate away from the camera without removing it fully. There is a ribbon attaching the edge of the plate to the camera.
Carefully pry the spudger under the black latch and lift gently upward. The ribbon will slide out easily.
With the ribbon unlatched, the entire metal plate should now be detached.
