Введение
You will be removing the back casing of the camera. You will need a Phillips #00 screwdriver and a spudger. You will then be directed to remove screws.
Выберете то, что вам нужно
Place thumb on the battery cover panel on the bottom of the device.
Slide the panel to the right away from the camera.
Slide the orange latch outward towards the corner of the camera.
The battery should pop out.
Remove the battery and reattach the cover.
After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
Carefully pry the back case away from the camera and then gently lift it off.
To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
2 участников успешно повторили данное руководство.
