Введение
This guide will show how to access the motherboard which will give you the ability to remove the lens and flash.
Выберете то, что вам нужно
Use the tweezers to lift the ZIF connector which is holding the ribbon cables that connect the LCD screen to the motherboard.
Remove the four 3.8 mm screws located near the bottom right and top left of the LCD base plate.
Using tweezers, lift up the retaining flap on the ZIF connector securing the button panel ribbon cable.
Slide the button panel ribbon cable out of its socket on the motherboard.
2 участников успешно повторили данное руководство.
Один комментарий
It would be nice to have a guide for replacing the flash capacitor.
