Nikon Coolpix S220 LCD Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix S220 LCD Replacement, Outer Cover: шаг 1, изображение 1 из 1
    • Remove the two 2.8 mm screws on the left side of the camera.
  2. Nikon Coolpix S220 LCD Replacement: шаг 2, изображение 1 из 1
    • Remove the four 2.8 mm screws on the right side of the camera.
  3. Nikon Coolpix S220 LCD Replacement: шаг 3, изображение 1 из 1
    • Remove the three 4.1 mm screws on the bottom of the camera.
  4. Nikon Coolpix S220 LCD Replacement: шаг 4, изображение 1 из 1
    • Gently lift the rear cover from the camera.
  5. Nikon Coolpix S220 LCD Replacement, LCD: шаг 5, изображение 1 из 1
    • Gently lift the screen out of its place.
    • You will need to hold the screen slightly above the camera because it will still be attached to the camera by an orange ribbon cable.
  6. Nikon Coolpix S220 LCD Replacement: шаг 6, изображение 1 из 1
    • Use the tweezers to lift the ZIF connector which is holding the ribbon cables that connect the LCD screen to the motherboard.
  7. Nikon Coolpix S220 LCD Replacement: шаг 7, изображение 1 из 1
    • Slowly pull the screen from the camera.
Заключение
2 участников успешно повторили данное руководство.
Shauna
Участник с: 04/05/11
798 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 12-32, Maness Spring 2011 Участник Cal Poly, Team 12-32, Maness Spring 2011
CPSU-MANESS-S11S12G32
4 членов
Автор 10 руководств
3 Комментариев
Where did you obtain the replacement LCD screen? I have two of the Coolpix's with broken LCD screens. I found your page looking for the dreaded "lens error", which the pulling on the lens idea helped me fix and now I would like to replace the cracked LCD screen in that camera. I had never thought it economically feasible. Thanks.
Roger Helbig - Ответить
Got my replacement LCD from eBay seller for very reasonable price.
The guide has you removing a couple, maybe 3 screws from the front side case, which I believe could have been left in place, but otherwise it is a good repair guide. If I had known how easy and cheap this repair was going to be, I would have done it over a year ago. I thought that I was going to have to find a repair shop (even looked and they wanted $90 per hour just for labor and did not have a price for the part(s). Glad I found the LCD on eBay and did it myself. Only took 5 minutes and IIRC, the LCD screen was less than $20 including shipping.
David Morris - Ответить
did you ever fix your camera
maya b - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 16
За всё время: 8,679
