Введение
Your Nikon Coolpix S30 camera is powered by two AA batteries. If your camera won't turn on, its batteries may be out of power. Follow this guide to remove the old batteries and install new ones. This may solve the problem and avoid other more complicated repairs. This guide will explain how to remove the battery compartment cover, change the batteries, and replace the cover securely.
Before starting this process, disconnect the camera from its charger.
Выберете то, что вам нужно
Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
Еще один человек закончил это руководство.
2 Комментариев
Cover not sliding open. Is there a way to loosen and adjust. Need to put in new batteries.
i am having same problem
