Введение
For this guide you will need a new LCD screen. If you are using iFixit tools, you will need a PH000 head and a T5 star head.
Выберете то, что вам нужно
Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
FIRST: remove the batteries.
Unscrew the four screws around the corners of the camera. This can be done using the iFixit kit's T5 (star tip screwdriver)
Unscrew the screw on the left (silver) first. It can be removed with the same tip (T5)
Change screwdriver tip to iFixit kit's PH000. This removes the screw on the right (black) It is a small Phillips head.
Spin the camera around and gently pull the screen towards you. This will allow easy access to components on the motherboard.
Remove connected strip by flipping up the small off-white plastic strip with tweezers.
Gently pull out the strip from the motherboard.
Remove screw that is now in the top right corner. This will detach the screen entirely.
Еще один человек закончил это руководство.
