Введение
The shutter button seems to malfunction whether it is not turning or not working. This guide will help you understand the problem.
Выберете то, что вам нужно
Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
Remove 2 screws from left side. (picture 1)
Remove 4 screws from bottom. (picture 2)
Remove 2 screws from right side. (picture 3)
Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
Remove the two screws.
Gently pull up to detach the frame. (picture 2)
Turn and hold the shutter bottom to the left and using a tweezer carefully remove the spring.
Еще один человек закончил это руководство.
