Введение
To replace the LCD screen of your camera, you'll need to go through a few steps of disassembly including the steps from the Back Cover replacement guide.
Выберете то, что вам нужно
Remove all four T5 Torx screws from the exterior of the camera.
Remove all three T5 Torx screws located at the bottom of the camera next to the battery compartment.
Remove the two screws located above the HDMI and USB logos that are inside the camera's battery compartment using a JIS000 screwdriver.
Using a plastic opening tool, pry the LCD screen out of its slot inside of the camera.
Before pulling the LCD Screen out of the camera, you will need to disconnect the ribbon connector that attaches the screen to the camera.
Gently pull the ribbon connector out of it's slot. You should be able to remove it without the need of any tools.
Еще один человек закончил это руководство.
