Nikon Coolpix S33 Motherboard Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix S33 Motherboard Replacement, Back Cover: шаг 1, изображение 1 из 2 Nikon Coolpix S33 Motherboard Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Remove battery before initiating this step to avoid the possibility of electric shock.
    • Remove all four T5 Torx screws from the exterior of the camera.
    • Remove all three T5 Torx screws located at the bottom of the camera next to the battery compartment.
  2. Nikon Coolpix S33 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Remove the two screws located above the HDMI and USB logos that are inside the camera's battery compartment using a JIS000 screwdriver.
  3. Nikon Coolpix S33 Motherboard Replacement: шаг 3, изображение 1 из 2 Nikon Coolpix S33 Motherboard Replacement: шаг 3, изображение 2 из 2
    • Using a plastic opening tool, gently remove the back cover from the camera.
  4. Nikon Coolpix S33 Motherboard Replacement, LCD: шаг 4, изображение 1 из 1
    • Be sure to have followed the steps to remove the Back Cover of your camera before beginning to replace the LCD Screen. This guide will cover just the replacement of the LCD Screen.
    • Using a plastic opening tool, pry the LCD screen out of its slot inside of the camera.
  5. Nikon Coolpix S33 Motherboard Replacement: шаг 5, изображение 1 из 1
    • Before pulling the LCD Screen out of the camera, you will need to disconnect the ribbon connector that attaches the screen to the camera.
    • Gently pull the ribbon connector out of it's slot. You should be able to remove it without the need of any tools.
  6. Nikon Coolpix S33 Motherboard Replacement, Motherboard: шаг 6, изображение 1 из 2 Nikon Coolpix S33 Motherboard Replacement, Motherboard: шаг 6, изображение 2 из 2
    • Remove all three 15'' Torx screws. Gently pry off the LCD holder using a plastic opening tool.
    • Peel off the connecting tape under the LCD holder to disconnect it completely.
  7. Nikon Coolpix S33 Motherboard Replacement: шаг 7, изображение 1 из 1
    • Peel back black electrical tape and disconnect the ribbon connectors from the mother board.
    • Disconect the wires from the motherboard.
    • Take out the two 15'' Phillips screws, as shown in the image, using a Phillips screwdriver.
  8. Nikon Coolpix S33 Motherboard Replacement: шаг 8, изображение 1 из 1
    • Gently pry off the motherboard using a plastic opening tool.
Заключение
5 участников успешно повторили данное руководство.
Maria Frias
Участник с: 02/18/16
564 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 16-3, Blackwell Winter 2016 Участник USF Tampa, Team 16-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G3
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 24
За всё время: 2,286
