Введение
This casing not only protects the lense, but acts as the decorative silver plastic running around the side of the camera, and holds the buttons on top.
It may need replacement in the event a button is broken, or any of the casing is cracked while using the camera.
Запчасти
Детали не указаны.
  1. Slide the battery door open with a finger or thumb and release it so the door opens.
    • Slide the battery door open with a finger or thumb and release it so the door opens.
  2. Push the orange tab back and the battery will pop out.
    • Push the orange tab back and the battery will pop out.
  3. Remove four 2mm Phillips #000 screws. Remove two black 3mm Phillips #000 screws. Remove one 4mm Phillips #000 screws.
    • Remove four 2mm Phillips #000 screws.
    • Remove two black 3mm Phillips #000 screws.
    • Remove one 4mm Phillips #000 screws.
    • Remove two silver 3mm Phillips #000 screws.
  4. Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart. Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
    • Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
  5. Turn the camera over. Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera. Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
    • Turn the camera over.
    • Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
  6. Remove the single 3mm Phillips #000 screw from the back of the camera.
    • Remove the single 3mm Phillips #000 screw from the back of the camera.
  7. Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing. Desolder the two wires connecting the casing to the motherboard.
    • Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing.
    • Desolder the two wires connecting the casing to the motherboard.
    • Work carefully so that you do not break the soldered wires.
Заключение
Matina Newsom
Участник с: 21.02.2018
755 Репутация
Автор 8 руководств
Команда
University of North Texas, Team S4-G1, Thompson Spring 2018 Участник University of North Texas, Team S4-G1, Thompson Spring 2018
UNT-THOMPSON-S18S4G1
5 членов
Автор 16 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 184
