Введение
You will need a #00 phillip's head screwdriver and a black spudger (or equivalent tool).
Запчасти
Никакие детали не требуются.
  1. Turn over camera to find 5 apparent screws.
    • Turn over camera to find 5 apparent screws.
  2. Remove all 5 screws from the bottom of the camera and store them carefully.
    • Remove all 5 screws from the bottom of the camera and store them carefully.
  3. Open battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of orange lever. Remove this screw.
    • Open battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of orange lever. Remove this screw.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Rotate camera to find side panel with lanyard attachment. Detach side panel by lifting bottom corner slightly with the spudger.
    • Rotate camera to find side panel with lanyard attachment. Detach side panel by lifting bottom corner slightly with the spudger.
  6. Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
    • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  7. With back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
    • With back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
  8. Find the five screws on the metal plate and remove them. One of them is in a hole in the corner of the metal plate. Also remove the screw at the bottom of the camera. Carefully lift metal plate from the right side to reveal a ribbon connected to the motherboard.
    • Find the five screws on the metal plate and remove them. One of them is in a hole in the corner of the metal plate.
    • Also remove the screw at the bottom of the camera.
    • Carefully lift metal plate from the right side to reveal a ribbon connected to the motherboard.
  9. Lift the white flap with the spudger to release the ribbon and remove back metal plate. Lift the white flap with the spudger to release the ribbon and remove back metal plate.
    • Lift the white flap with the spudger to release the ribbon and remove back metal plate.
  10. Lift the two ribbons with the spudger to disconnect the lens and pull it out. Lift the two ribbons with the spudger to disconnect the lens and pull it out. Lift the two ribbons with the spudger to disconnect the lens and pull it out.
    • Lift the two ribbons with the spudger to disconnect the lens and pull it out.
Заключение
Ryan
Участник с: 12.04.2011
131 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 18-24, Garner Spring 2011 Member of Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 3
За всё время: 1,061
