Введение
If the screen on your Nikon Coolpix S5200 is unresponsive or not working, use this repair guide to replace the entire screen,
Выберете то, что вам нужно
There are four 0.1 mm screws holding the front and back of the camera together all along the outside of the camera
Use the Phillips Head screw driver head to remove the four 0.1 mm screws surrounding the outer edges of the camera
Carefully remove the LCD screen from the silver plate that once held it in place by pulling it away from the internal components
Remove the six designated screws sized 0.1 mm from the metal plate using a Phillip's Head screwdriver in size PH00.
Carefully remove the LCD screen by pulling it away from the camera. Repeat these steps in reverse order to install the new LCD screen.
Один комментарий
Shouldn't the replacement LCD screen be considered a part? It is in fact very difficult to replace it without having the part to replace.
