Nikon Coolpix S630 Back Cover Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix S630 Back Cover Replacement, Battery Compartment: шаг 1, изображение 1 из 1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Back Cover Replacement, Battery: шаг 2, изображение 1 из 1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Back Cover Replacement, Memory Card: шаг 3, изображение 1 из 1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: шаг 4, изображение 1 из 3 Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: шаг 4, изображение 2 из 3 Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: шаг 4, изображение 3 из 3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  5. Nikon Coolpix S630 Back Cover Replacement: шаг 5, изображение 1 из 1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  6. Nikon Coolpix S630 Back Cover Replacement, Detaching Ribbon: шаг 6, изображение 1 из 2 Nikon Coolpix S630 Back Cover Replacement, Detaching Ribbon: шаг 6, изображение 2 из 2
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
Заключение
Anna Katrina
Участник с: 04/18/13
28 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 8-56, Johann Spring 2013 Участник Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 членов
Автор 18 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 468
