Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Before replacing your battery cover door for your Nikon Coolpix S630 you would need to read how to remove back panel and front panel. Removing both back and front panels are necessary to starting this guide.
Запчасти
Детали не указаны.
  1. The battery compartment is located on the bottom of the camera.
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Slide the yellow tab towards the back of the camera.
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Press the memory card down into the camera.
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Unscrew the two 3.5mm Phillips screws from the side with the AV outlet. Unscrew the 3.5mm Phillips screw from the opposite side of the camera. Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  5. Carefully remove the back casing from the camera.
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  6. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  7. Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up. Gently pull the ribbon from the logic board with tweezers.
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  8. Locate a small, rectangular flap above the battery cover door.
    • Locate a small, rectangular flap above the battery cover door.
    • Push the small, rectangular flap back through the hole.
  9. Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Make sure to hold the camera down when removing the front cover.
  10. Locate the battery cover door.
    • Locate the battery cover door.
  11. Press and slide the cover door open. Press and slide the cover door open.
    • Press and slide the cover door open.
  12. Locate the small rod that is securing the door in place
    • Locate the small rod that is securing the door in place
    • Using a tweezers, grab the rod and slowly pull the rod out
    • Note: Be careful as you try to pull the rod out because the spring may pop out
  13. Replace battery cover door.
    • Replace battery cover door.
    • Note: To reinstall a new battery cover door, make sure you have these parts: spring, rod, and the battery cover door.
  14. Place battery cover door back into place with spring between the insertion holes.
    • Place battery cover door back into place with spring between the insertion holes.
    • Using a tweezers, gently slide the rod through the insertion holes and through the spring.
Заключение
Еще один человек закончил это руководство.
Aulivia Bounchaleun
Участник с: 19.04.2013
10 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 8-56, Johann Spring 2013 Участник Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 членов
Автор 9 руководств
Один комментарий
I am stuck on step 8. How am I supposed to hold it down and pull the front cover off. I can only get the corner up where the battery goes.
toolshell - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 998
