Инструменты
Запчасти
Детали не указаны.
The battery compartment is located on the bottom of the camera.
Place your thumb on the battery door.
Slide the door away from the camera in the direction the arrow points to.
Slide the yellow tab towards the back of the camera.
The battery should pop out.
Remove the battery.
Press the memory card down into the camera.
The memory card should pop out.
Remove the memory card.
Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
Gently pull the ribbon from the logic board with tweezers.
With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
Locate a small, rectangular flap above the battery cover door.
Push the small, rectangular flap back through the hole.
Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
