Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will go through the steps to properly and safely remove the LCD screen from your Nikon Coolpix S630 for repair, replacement, or maintenance.
Запчасти
Детали не указаны.
  1. The battery compartment is located on the bottom of the camera.
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Slide the yellow tab towards the back of the camera.
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Press the memory card down into the camera.
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  5. Unscrew the two 3.5mm Phillips screws from the side with the AV outlet. Unscrew the 3.5mm Phillips screw from the opposite side of the camera. Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  6. Carefully remove the back casing from the camera.
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  7. Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up. Gently pull the ribbon from the logic board with tweezers.
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  8. Lift LCD screen carefully from the metal casing Be cautious when lifting screen as it is still connected to the logic board by two ribbons Lift the two tabs for both ribbons with a plastic case opener like in the previous step
    • Lift LCD screen carefully from the metal casing
    • Be cautious when lifting screen as it is still connected to the logic board by two ribbons
    • Lift the two tabs for both ribbons with a plastic case opener like in the previous step
    • Pull out ribbons gently from the logic board with tweezers to disconnect screen
  9. Disconnect the LCD screen from the logic board!
    • Disconnect the LCD screen from the logic board!
Заключение
Anna Katrina
Участник с: 18.04.2013
1 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 8-56, Johann Spring 2013 Участник Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 членов
Автор 18 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 877
