Nikon Coolpix S630 Lens Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix S630 Lens Replacement, Battery Compartment: шаг 1, изображение 1 из 1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Lens Replacement, Battery: шаг 2, изображение 1 из 1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Lens Replacement, Memory Card: шаг 3, изображение 1 из 1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Lens Replacement, Back Cover Removal: шаг 4, изображение 1 из 3 Nikon Coolpix S630 Lens Replacement, Back Cover Removal: шаг 4, изображение 2 из 3 Nikon Coolpix S630 Lens Replacement, Back Cover Removal: шаг 4, изображение 3 из 3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  5. Nikon Coolpix S630 Lens Replacement: шаг 5, изображение 1 из 1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  6. Nikon Coolpix S630 Lens Replacement, Detaching Ribbon: шаг 6, изображение 1 из 2 Nikon Coolpix S630 Lens Replacement, Detaching Ribbon: шаг 6, изображение 2 из 2
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  7. Nikon Coolpix S630 Lens Replacement, Lens: шаг 7, изображение 1 из 1
    • Remove the metal casing from the logic board.
    • There are three ribbons that connect the lens to the logic board as shown.
    • Place the flat end of the spudger underneath one of the black flaps. Carefully lift the flap with the spudger and gently slide the ribbon out.
    • Repeat the above process to remove the remaining two ribbons.
  8. Nikon Coolpix S630 Lens Replacement: шаг 8, изображение 1 из 1
    • Unscrew the four, 3.5mm Phillips screws that hold down the metal plate.
  9. Nikon Coolpix S630 Lens Replacement: шаг 9, изображение 1 из 3 Nikon Coolpix S630 Lens Replacement: шаг 9, изображение 2 из 3 Nikon Coolpix S630 Lens Replacement: шаг 9, изображение 3 из 3
    • Carefully lift the lens off of the front cover.
Заключение
Aulivia Bounchaleun
Участник с: 04/19/13
10 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 8-56, Johann Spring 2013 Участник Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 членов
Автор 18 руководств
Один комментарий
Between steps 6 and 7 there should be a step to remove the LCD screen, metal casing and ribbon cables.
There is a 5th screw required to remove the lens in step 8. It’s under the fat ribbon cable. Deep in a hole.
Rob G - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 1,689
