Введение
This guide will allow you to disassemble the camera to the point where the screen can be replaced, help you replace it and provide direction for reassembly.
Выберете то, что вам нужно
Turn the camera upside down and locate the two, black screws.
Using the Philips #00 Screwdriver, remove each screw.
Rotate the camera to the left side and remove the two, black, #00 Philips screws.
Rotate the camera to the right side and remove the two, black, #00 Philips screws.
Using the Philips #00 Screwdriver, remove the two screws that are holding the keypad.
Gently pull the display away from the camera body.
Fold the display away from the camera
Remove the visible midframe screws.
There is a screw beneath the foam square that must be removed as well.
The screw holding the silver wrist-strap loop on the side of the camera must also be removed.
Gently lift the midframe up and out of the device.
Take the new display and orient it the same way as the old screen before it was removed.
Gently slide the end of the electric ribbon into the connector.
To make sure that the ribbon is completely in the connector give it a firm push but don't force anything. The ribbon should slide in with only a little resistance.
