Введение
In this guide, we will go over the steps to remove the motherboard from a Nikon Coolpix S800c.
Выберете то, что вам нужно
Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
Unscrew all 6 visible screws that secure the motherboard into place using a Phillips head screwdriver (found in iFixit tool kit).
Pull the shown panel off of the motherboard to expose the Image sensor connection
Pull the gray panels back to allow the hidden micro usb and hdmi insert connectors to come free.
Use a Metal Spudger to help with the process to get these connectors free from the frame.
Soldered wires attaching the motherboard to the camera body will need to be disconnected at the motherboard-end and the new wires on the replacement motherboard will need to be soldered on. To reassemble your device, follow these instructions in reverse order.
