Введение
The Coolpix S9050 was introduced in 2012 and discontinued in 2013
Выберете то, что вам нужно
Flip the camera upside down.
Slide the locking mechanism to the left.
Push yellow holding pin upward until battery pops up.
Pull out battery.
Tools Required: PH00 screwdriver
Remove the two screws on the left side of the camera.
Remove the two screws on the right side of the camera.
Remove the four screws from he bottom of the camera.
Remove the screw that is located on the inside of the battery chamber.
Use a blue pry tool and separate the black back plate from the camera.
Once the black plate is separated, carefully pull apart the back plate from the front half of the camera.
Take the blue pry tool and lift the brown latch on the ZIF connecter that holds the screen tab in place.
Once the brown latch on the ZIF connecter is lifted upward, carefully lift the screen and pull away from the camera.
The screen and screen tab will detach from the motherboard.
Take the new screen and slide the tab in to the ZIF connector that the previous screen was plugged in to.
Close the brown latch on the ZIF connector and fit the screen in the original slot.
Return the dial flap to its original position.
Follow the steps in reverse order to put the camera back together.
