Nikon D3000 LCD Screen Cover Replacement
Выберете то, что вам нужно
  1. Nikon D3000 LCD Screen Cover Replacement, LCD Screen Cover: шаг 1, изображение 1 из 1
    • Remove three 3 mm x 2.5 mm Phillips head screws from the bottom right back of the camera bottom.
    • Remove one 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom.
  2. Nikon D3000 LCD Screen Cover Replacement: шаг 2, изображение 1 из 3 Nikon D3000 LCD Screen Cover Replacement: шаг 2, изображение 2 из 3 Nikon D3000 LCD Screen Cover Replacement: шаг 2, изображение 3 из 3
    • Remove two 3 mm x 5.5 mm Phillips head screws from either side of the viewfinder.
    • Remove four 3 mm x 5.5 mm Phillips head screws above and below the USB port cover and above and below the SD card slot cover.
    • Remove two 3 mm x 4 mm Phillips head screws inside the SD card slot cover.
  3. Nikon D3000 LCD Screen Cover Replacement: шаг 3, изображение 1 из 3 Nikon D3000 LCD Screen Cover Replacement: шаг 3, изображение 2 из 3 Nikon D3000 LCD Screen Cover Replacement: шаг 3, изображение 3 из 3
    • Gently lift the back of the camera off, starting with the top first.
    • Lift off the bottom slightly to expose the ribbon connector connecting the back of the LCD screen to the motherboard of the camera and lift the black tab on the ribbon connector.
    • Pull the ribbon away from the connector to disconnect the back panel from the main body of the camera.
  4. Nikon D3000 LCD Screen Cover Replacement: шаг 4, изображение 1 из 2 Nikon D3000 LCD Screen Cover Replacement: шаг 4, изображение 2 из 2
    • Remove six 5 mm x 4mm head screws, then remove the metal plate from the plastic camera backing.
  5. Nikon D3000 LCD Screen Cover Replacement: шаг 5, изображение 1 из 1
    • Tape the buttons down on the front of the plastic camera backing in order to avoid losing them in the process.
    • Use a heat gun on the edges of the LCD screen cover in order to loosen the adhesive.
    • Use the prying tool to separate the LCD screen cover from the plastic camera backing (the LCD screen cover will come out towards the front).
    • Install a new LCD screen cover.
Заключение
5 участников успешно повторили данное руководство.
Flor
Участник с: 08/26/15
288 Репутация
1 руководство автора
Команда
USF Tampa, Team 14-7, Meier Fall 2015 Участник USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
4 членов
Автор 6 руководств
2 Комментариев
Where could I find a new LCD screen cover?
Aly Blackmore - Ответить
You can find them on eBay.
Mike Roedema - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 1,807
