Введение
Confirm with your user's manual for appropriate memory cards.
Locate the memory card compartment on the right side of the LCD screen.
Gently press and slide the grooved compartment door to the left.
Let go of the compartment door and it will swing open.
Insert the memory card imitating the diagram pictured outside the compartment door.
11 участников успешно повторили данное руководство.
Один комментарий
Hello is this about replacing the memory card compartment or just the memory card? Apparently the memory card compartment is not maintining the memory, it’s not keeping it in the memor slot keeps popping back up. How do I fix this? Can I replace the housing?
