Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
LCD screens are known to shatter when dropped. In this guide you will replace the LCD screen that is on the inside of the camera.
Выберете то, что вам нужно
Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
Remove the six 3.0 mm Philips #0 screws on the inside of the back panel which contains the LCD screen.
Remove the metal casing containing the LCD screen using the plastic opening tool.
4 участников успешно повторили данное руководство.
