Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Make sure to remove any memory cards and the battery before doing these steps.
Выберете то, что вам нужно
Remove the 2 screws beside the memory slots, then close the cover.
Remove the 2 screws under the rubber grip part by peeling back the rubber grip
Try not to damage the double sided adhesive under the rubber.
Remove the 2 screws under the rubber pad.
Try not to damage the double-sided adhesive under the rubber.
Note: There is a 3rd screw under the flap, which holds the back to the top. If needing to remove the back panel not just the memory cover flap, it can be removed at this time as well.
Lift out the assembly panel, it should come free without much force.
May open the panel to release it.
