Nikon D5000 Speaker Replacement
Выберете то, что вам нужно
  1. Nikon D5000 Speaker Replacement, Back Panel: шаг 1, изображение 1 из 3 Nikon D5000 Speaker Replacement, Back Panel: шаг 1, изображение 2 из 3 Nikon D5000 Speaker Replacement, Back Panel: шаг 1, изображение 3 из 3
    • The battery door has been removed for clarity, but is not necessary. See this guide for how to remove it.
    • Unscrew the eight Phillips #00 screws on the back panel:
    • Two 2.5x6mm screws above the screen.
    • One 3x6mm screw on the upper part of each side (two total; right side shown).
    • One 3x7.5mm screw on the lower part of each side (two total).
    • Two 3x4.5mm screws on the bottom.
  2. Nikon D5000 Speaker Replacement: шаг 2, изображение 1 из 3 Nikon D5000 Speaker Replacement: шаг 2, изображение 2 из 3 Nikon D5000 Speaker Replacement: шаг 2, изображение 3 из 3
    • Pull the back panel up, then tilt it back. There will be two cables still holding it on.
    • Doing this will also release the connector cover on the left side. Set it aside for now, but remember to reinstall it later.
    • Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
    • This procedure also applies to all of the other ribbon cables in the D5000.
    • Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
  3. Nikon D5000 Speaker Replacement, Speaker: шаг 3, изображение 1 из 2 Nikon D5000 Speaker Replacement, Speaker: шаг 3, изображение 2 из 2
    • The speaker is mounted to the underside of the back panel. There is a a metal shield that holds it on.
    • Remove the four Phillips #00 screws securing the shield:
    • Three silver 3x4mm screws.
    • One black 3x3mm screw.
    • Remove the shield.
    • With the shield off, the navigation buttons and "Lv" button are free to move and rotate. Check alignment before replacement.
  4. Nikon D5000 Speaker Replacement: шаг 4, изображение 1 из 1
    • Lift the blue tape on the ribbon cable.
    • Desolder the two leads to the speaker.
  5. Nikon D5000 Speaker Replacement: шаг 5, изображение 1 из 1
    • Pry the speaker out of its cavity.
Заключение
Jacob Rardin
Участник с: 04/14/14
1 390 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 13-28, Maness Spring 2014 Участник Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 917
