Nikon D5100 Front Panel Replacement
Выберете то, что вам нужно
  1. Nikon D5100 Front Panel Replacement, Front Panel: шаг 1, изображение 1 из 3 Nikon D5100 Front Panel Replacement, Front Panel: шаг 1, изображение 2 из 3 Nikon D5100 Front Panel Replacement, Front Panel: шаг 1, изображение 3 из 3
    • Using a screwdriver, remove 7 Phillips #00 screws from the front panel of the camera chassis.
    • The D5100 is held together by a large number of screws of varying lengths, so be very careful to keep track of all your fasteners!
  2. Nikon D5100 Front Panel Replacement: шаг 2, изображение 1 из 1
    • Carefully peel back the rubber hand grip, which is attached to the camera body with strong adhesive.
    • Remove the two Phillips #00 screws hidden beneath the hand grip.
    • One screw is not shown in this image, although its location is circled: it is hidden in the upper portion of the hand grip, with its head facing downward.
  3. Nikon D5100 Front Panel Replacement: шаг 3, изображение 1 из 1
    • Open the battery compartment and remove the battery (not shown here).
    • Remove the Phillips #00 screw hidden deep within the compartment.
    • You may need to use a screwdriver extender to accomplish this.
  4. Nikon D5100 Front Panel Replacement: шаг 4, изображение 1 из 1
    • Firmly separate the front panel from the main camera body. You will feel some resistance since the chassis parts fit tightly together; this is to be expected.
Заключение
2 участников успешно повторили данное руководство.
Liz
Участник с: 04/25/14
1 311 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 10-54, Amido Spring 2014 Участник Cal Poly, Team 10-54, Amido Spring 2014
CPSU-AMIDO-S14S10G54
4 членов
Автор 5 руководств
2 Комментариев
I am about to replace the front panel of my D5100; I have the replacement panel already and it appears some things are inaccurate here. The two screws shown in the third picture of step 2 would not affect the front panel; instead there are two screws on the side next to the connector port that must be removed. It also appears there is no screw in the middle of the hand grip since there is no hole in my replacement panel. There do appear to be two screws on the side of the hand grip, making a total of three under the grip. Nonetheless, this is very helpful, and I thank you.
Tom Spiglanin - Ответить
Where did you get the replacement? Because I have a crack in my front panel but I can't find where to get a new one…
Valentin Benke -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 15
За последние 30 дней: 45
За всё время: 5,745
