Введение
Use this guide to replace the CCD sensor board.
Инструменты
Запчасти
Детали не указаны.
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Carefully pull the bottom cover to separate it from the body of the D70.
Remove the bottom cover from the D70.
Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
Use your fingernail to flip up the ZIF cable retaining flap on each socket.
Pull the ribbon cable straight out of its socket.
Carefully peel back the piece of tape covering the Compact Flash ribbon cable socket.
Use your fingernails to carefully pull the ZIF cable lock away from its socket.
Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
Remove the four 4.3 mm Phillips screws securing the memory compression board to the D70.
Use a pair of tweezers to pull the USB connector bracket away from the edge of the memory compression board.
Grab the memory compression board by its edges at the position shown in the first picture.
Pull the memory compression board straight up off the DC/DC board to avoid damaging the connector on the underside of the memory compression board.
De-route the two leads routed over the connector boxed in yellow.
Use your thumbnails to push the connector out of its socket.
Remove the two Phillips screws securing the grip side of the rear cover to the D70.
Remove the two Phillips screws securing the DC-In side of the rear cover to the D70.
Carefully pull the sides of the rear cover away from the body of the D70.
Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
Peel back the piece of tape connecting the iron core around the CCD board ribbon cable to the inner case.
25 участников успешно повторили данное руководство.
Комментариев: 2
Great instructions.
One important note: When re-installing the CCD board ribbon cable into the CCD board, the cable will go into the connector about 2mm and feel like it's seated. However, the cable must go 3mm-4mm into the connector. Otherwise, you will get a "This Card Cannot Be Used" error message each time you depress the shutter button.
Great article.
