Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This is an internal prerequisite that should remain unpublished.
Выберете то, что вам нужно
Use a plastic opening tool to carefully pry up the flash unit at the point shown in the picture.
Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
Use the sharp end of a metal spudger or a razor blade to peel the sticker out of the center of the automatic/manual focus switch.
Remove the 6.3 mm shouldered Phillips screw from the center of the automatic/manual focus switch.
Pull the automatic/manual focus switch away from the front cover.
