Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Carefully pull the bottom cover to separate it from the body of the D70.
Remove the bottom cover from the D70.
Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
Remove the two 4.8 mm Phillips screws securing the port side of the rear cover to the D70.
Use your fingernail to flip up the ZIF locking flap on the LCD ribbon cable socket.
Pull the LCD board ribbon cable out of its socket.
Carefully pull the sides of the rear cover away from the body of the D70.
Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
Use a plastic opening tool to carefully pry up the flash unit at the point shown in the picture.
Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
Remove the two 4.3 mm Phillips screws on the face of the front cover.
Use the sharp end of a metal spudger or a razor blade to peel the sticker out of the center of the automatic/manual focus switch.
Remove the 6.3 mm shouldered Phillips screw from the center of the automatic/manual focus switch.
Pull the automatic/manual focus switch away from the front cover.
Remove the 5.7 mm Phillips screw in the top corner of the battery compartment.
Remove the 4.2 mm Phillips screw securing the lower edge of the grip to the front of the D70.
5 участников успешно повторили данное руководство.
