Введение
Use this guide to replace the LCD board, which also houses the physical switches for the buttons on the rear cover.
Выберете то, что вам нужно
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
Remove the two 4.8 mm Phillips screws securing the port side of the rear cover to the D70.
Use your fingernail to flip up the ZIF locking flap on the LCD ribbon cable socket.
Pull the LCD board ribbon cable out of its socket.
Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
Use your thumbnails to push the ZIF cable lock toward the LCD.
Pull the LCD ribbon cable out of its socket.
Remove the two 4.8 mm Phillips screws securing the LCD bracket to the rear cover.
Lift the LCD bracket out of the rear cover.
Remove the three 3.1 mm Phillips screws securing the LCD board to the rear cover.
4 участников успешно повторили данное руководство.
