Введение
In the event that the bottom cover is damaged or specific wires require access, the bottom cover needs to be removed or replaced. For safety purposes, please remove the battery before working with any electronic components.
Инструменты
Запчасти
Детали не указаны.
Use the #00 Phillips-head screwdriver to remove the three 8.44 mm screws.
Use the #00 Phillips-head screwdriver to remove the four 6.3 mm screws.
Use the #00 Phillips-head screwdriver to remove the 2.9 mm screw.
3 участников успешно повторили данное руководство.
