Введение
If you are having trouble mounting the lens and you are sure you have the correct lens type (see the camera manual for types of lenses that can be used), then use this guide to assist with replacing the lens mount.
Запчасти
Никакие детали не требуются.
  1. Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
    • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  2. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Remove lens mount from the camera.
    • Remove lens mount from the camera.
    • Be careful not to lose any of the three loose pieces that are under the lens mount.
Заключение
4 участников успешно повторили данное руководство.
Zachary Phillips
Участник с: 08.04.2011
205 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 25-26, Garner Spring 2011 Member of Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 членов
Автор 7 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 25
За всё время: 4,593
