Введение
Changing the tubes when the Ninja Coffee Bar® Single-Serve System leaks water from the bottom will require some time but can fix a few problems. Ensure the device is in a secure open area where you will not lose any screws because they are small. You will want the magnetic pad provided in the iFixit tool kit. Warning: be careful when removing the protective plate because many wires cannot be disconnected.
Before beginning the repair, turn off the coffee maker and unplug the device from the power outlet.
Выберете то, что вам нужно
Remove the eight 6 mm screws using the Phillips #1 screwdriver.
Remove the bottom cover.
Remove the three 6 mm screws with the Phillips #1 screwdriver.
Remove the plastic cover.
Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
