Введение
This guide will show how to remove the heated plate from the coffee machine.
Выберете то, что вам нужно
Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
Еще один человек закончил это руководство.
