Введение
This guide will show how to remove the water pump from the coffee machine.
Выберете то, что вам нужно
Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
Detach various colored cords from one another, using both hands to place thumb and index finger to hold each grip then separate by pulling with the degree of force.
Grip the bottom end of the panel and pull it towards you to remove the module from the machine.
Remove the three 0.6 cm screws, using Phillips #1 screwdriver with Extender 4.
Pull the water tube towards you to detach the water's tube top from the machine.
Grip on the diamond shaped black holder lid and pull it away to separate the tube from the machine.
Еще один человек закончил это руководство.
